To answer on MWJB's behalf...
Yup. You'll want to get a few resistors in standard values if you really want to get finite with the adjustment. 250R, 270R, 330R, 390R and 430R. I don't think you'll over dissapate the tubes even with a 250R but you may get better performance with a cooler bias. Listening is the best way to set guitar amp bias. Well, that and looking to make sure the power tubes aren't glowing the screens or plates.
Many guitar amps have the screens very close to the plate voltage. It's not a problem. If we wanted to get the lowest hamonic distortion figure we could pay more attention to the data sheets. There is a good technical reason to keep the screens below the plate voltages but I can't remember the specifics. Some guitar amps actually have the screen voltage higher than the plates and are revered for their tone. Since guitar amps are intended to color the sound with extra overtones, harmonics and other distortions it's usually counter productive to take the data sheets too seriously. The posted voltages in the data sheets are just examples, not ideals. Tubes are pretty flexible and can operate fine with parameters not listed on the data sheets. Saavy techs use the data sheets as a reference guide to the tube in question to get an idea of it's operating characteristics and maximum limits. With a 1k resistor between the plates and screens instead of a choke you should have no trouble keeping the screens below the plates by a safe margin.
Originally posted by Rocketrob
View Post
View Post
