Sounds like your on it. I'm surprised to not read the usual "This amp rules!" that most guy's post at first working start up. Perhaps your immune to that sort of thing. But I hope it doesn't mean that you don't really like it. Anyway...
Tweaking will bring it all in. A neat trick for the bright switch is to leave the stock 47p cap in place and have the switch add another 100p in parallel. You'll hear that fo shizzle and it'll help you get those snappy cleans.
I think the PI voltages are fine without being raised. The preamp will probably benefit from getting the voltage down to spec. It will be "brown"er as they say. Less stringent and not as spikey on attack. It'll also soften the bass a little. Just stick a bigger resistor in there. Your amp doesn't have all the other tubes pulling current through that 56k resistor so there's less voltage drop. Reducing the voltage on the pre and adding more bright switch should be a nice combo.
Power tubes are running pretty hot for idle. May actually be OK for cathode bias but you will probably get better clean volume and tighter bottom end with a cooler bias.
Something I do when I'm designing with split plate loads is temporarily wire a 100k pot in as the plate load taking the signal from the wiper. Then I can choose what I want, remove the pot without turning it and measure each leg to wiper. Then choose fixed resistor values that are close.
Kudos
Kudos
