Turning down the voltages with a variac is also reducing your filament voltages. This could be causing your problem. Set up the amp as you tested it and check the filament voltage.
About the grounding scheme... I usually have my best results using a two star ground system. Grounding everything at the PT bolt on amps bigger than single ended types can cause hum IME. Pehaps it's due the the current being higher, not sure, but in AB1 amps I find that one ground point near the input jack used for all preamp grounds and a second near the mains for all power amp and power supply grounds works for me. In fact on some amps (amps with reverb especially) I use a third ground point at mid chassis for the reverb, PI and presence control grounds. I usually just ground all filters at the PA ground point but if the amp has any hum or oscillations I'll try changing the preamp filter grounds to one of the other ground points. Just something to try if the amp hums when you get it working.
