So I have a tweed deluxe output and power transformer but I don't want to build a 5E3. Anyone out there have any suggestions. The OT is a 1750E and the power transformer is 310-0-310 with a 120v primary. I'd like to keep things simple maybe only one channel and go for clean headroom.
What to build besides a 5E3?
Ok so I've decided I want to try taking the BF Princeton idea but without the trem or reverb and build it using the other 12ax7 triode for a LTPI. Im not sure how to implement this idea exactly. I have what I believe to be a rough schematic of the idea but the component values are where I get a little lost. Would I just use the typical fender normal channel values for the first 2 gain stages and tonestack then have the output of that feed into the typical LTPI? The reason I ask is because I though the channels mix before the LTPI in most 2 channel fenders.
If anyone can help with this one it would be great.
Cheers
If you are going to do it without the 'verb, for goodness sake put a bias-wiggle trem in. You'll still have more than enough stages to turn it into a gain monster. And since you are going to do an LTP, copy the 5G9 PI and output stages, together with the 5G9 LFO stage(s). Then it'll smoke.Building a better world (one tube amp at a time)
Originally posted by ncusack View PostIf I were to do that why not just build a 6G2? Brown PrincetonBuilding a better world (one tube amp at a time)
Originally posted by tubeswell View PostThe 5G9 trem (i.e.: with the CF stage) is fantastic. The 6G2 trem is so-so
My 6G3 has a trem similar to the 6G2 (half a 12AX7) and my 5F4 I built with the trem of a 6G11 Vibrolux (i.e. similar to the 5G9 with a whole 12AX7).
The "whole tube trem" is more, well... LUSH.
And I think you'll get all the assistance you need from this forum.
Originally posted by ncusack View PostTubeswell do you think you could assist me with the design for this idea. Do you think the iron i've mentioned will still be suited for a project like this?Building a better world (one tube amp at a time)
Originally posted by ncusack View PostBig thing for me is the use of the 1750E output its only rated at 15W. I have this Iron on hand and would like to use it. As far as I know that wont cut it in a marshall build. Id like to keep things simple and aim for a decent clean tone.
