Hi, I am wondering how this works in the Fender Bassmans and other schematics I've seen this pattern. The circuit I am working with is from schematic AA864. With a 12AT7 it has an input line into the grid (pin 2) and a 470 ohm resistor coming off the cathodes into a junction of 2-1 meg grid resistors and a 23K resistor. The 23K is then connected to a 0.1uF cap and an 820 ohm resistor from the feedback line off the OT. The other end of the cap goes to the other grid (pin 7).
How does this work?? And how much room is there to work with wrt the values used? I have a 24K resistor and wonder if it will work for the 23K and what changes it makes. If not much, how much change would be noticeable and what will happen. This is one of the only parts of amps I can't figure out what is going on. Thanks
