Upon reflection, I should have posted this here instead of "kit amps"
Some blindingly obvious things to do in an amp build
Here are some things that at least to me are incredibly obvious things that need included in an amp build that hardly ever are.
1. One fuse per winding on the power transformer. The AC power inlet fuse is there to prevent fires. It's a happy accident if it protects the power transformer. Put a fuse in the heater winding(s) and one in each side of the centertapped high voltage if so provided.
2. Install silicon safety diodes in series with a tube rectifer, one in series with each anode (not cathode like I first wrote 8-0 ). Then if the tube shorts, the silicon picks up the slack and does not let your power transformer and filter caps die.
3. Put bleeder resistors across the first filter cap. This ensures that it will bleed down in some small time to save YOU from shocks when you service it. Pick how much current you can allocate to them, or how much power you can waste, then figure the resistors. For instance, if you have a 400V supply that goes to 500V if there are no tubes in, and you don't want to waste more than half a watt, calculate P = Vsquared/R = 0.5 and get R = 500K, and rated at 1W. A 470K 1W would do, as would two 220K half-watts in series, or two 1M half watts in parallel.
4. Build it with a 3-wire AC cord and safety grounded chassis. There is no two-wire magic.
There are other things, but these scream to be done on any new build. Build it so it is harder to kill, and easier to service.
Originally posted by R.G.
Originally posted by Gibsonman63
