TopCoat Wire
  • TopCoat Wire
    Not all TopCoat is Created equal.
    I like the Pre Tinned 20 Gauge wire.
    The Problem is with the Insulation.
    I bought some from Mojo, it looks great.
    But, when you go to solder on it It Melts and gets gooy to Damn Easy.
    I cut some Access TopCoat from a Transformer Tail.
    It is what I'm looking for.
    It is nearly as tough and heat resistant as Teflon.
    I wonder where they get the stuff?
    I've tried the Tube Depot, and it might be a little tougher than the Mojo, but It's not Pre-Tinned.
    Your Thoughts!
    B_T
    Terry
    PTFE High Temperature Stranded Wire
    copper stranded, silver plated, teflon coated is the state of the art, it's aircraft grade, 1000 volt, 200C.
      They make heat sinks for soldering wire, they look like little thin alligator clips. I often just use a small alligator clip..CLip to the wire just between the end of the insulation and the solder work. Got a dull pair of dikes? A weak rubber band around the handle, then clamp it onto the wire just at the end of the insulation, as if you were going to snip the wire, but don;t squeeze the dikes. The sharpnes of the blade means you can get it very close to the solder but still not in the way.
      Here, I found them. I searched "heat sink tool" at MCM.
      A little over a dollar each.
      Clip On Heat Sink Kit 5 PER Kit | HEATSINK KIT | Distributed By MCM
