For discussion, I have a working prototype, it is far from complete..
Using three 6418.. as preamp and paraphase PI.
The first is wired as a pentode, second and third in Triodmode.
Two 5840 in push pull
Using a Max 1044 to boost voltage, from 12v to 61v. The voltage drops to 49V when the tubes start conducting
using a 70v line transformer tap common and .62w for the plates and 2.5w as center tap.
Will post Schematic once I draw one.. I am sure this can be refined for more volume (better voltage multiplier) and more clean head room..
sample here
All suggestions on values welcome..
I do not want to build a SMPS and I want to use BATT to run.. So if anyone has a better voltage Multiplier please let me know..
sample here
