Matchless Lightning?
  • Matchless Lightning?
    Hey Guys, I'm looking at building another Matchless Lightning clone using the Ceriatone layout. I would like to use 6v6's instead of el84's and was wondering what changes would I have to make in order to accomplish this? I have attached the layout that I have already have done. Any help would be greatly appreciated.
    Chuck.
    http://www.ceriatone.com/images/layoutPic/matchlessLayout/Lightningceriatone.jpg
    anyone?
      Have you done your homework?
      What is the heater requirements of a 6V6 compared to a EL84?
      Is the present transformer sufficient?
      What is the effective ac plate resistance of a 6V6 compared to a EL84?
      Will your output transformer match up?
      What are the bias requirements of a 6V6 at the plate voltage you have?
      See where I am going with this?
        hey jazz p bass, yes, I hear ya, point taken. Homework!
          I'll just stick wth el84's, the transformers I have are new matchless trannys with a 6.3CT/4A hearter winding,5V/3A winding and a 564 CT/.08A. The out put tranny is 4,8,and 16 ohm tap with 4k ohm B+voltage. So I figure 6v6's would be no provlem for these trannys.
          chuck.
            I have done some conversion work on a Valve Jr, and putting a 6V6 in was relatively easy. Just do a little homework. 6V6's and EL84's need similar signal levels to drive properly, so it's not a tough one.
              hey trevorus, I went ahead and used el84's as the layout called for but I'm not liking the brightness of this amp. I want to cut down the brightness and the volume as well. The amp is super loud for fifteen watts. I can barely touch the vol control and it's loud, I would like to tame this high volume as well as the brightness.The amp is really to clean and sparkly for my tastes. when the vol is turned up past 6 I get a god overdrive/tube saturation though. Any suggestions on how to tame the brightness and less vol on lower setttings?
              Chuck.
                Take that 100 pf capacitor off of the volume control. That should tame the brightness a bit. You could also make it switchable. As far as power goes, you could add a triode mode switch that would drop the power down to about 5-7 watts. That would definitely drive earlier, and at less volume. That will change the tone a bit, though.
                  Hey Trevorus, yes, i'll remove the cap from the vol pot and see how tah works, I coulda triode mode switch, athough my experience with cutting the power in half diffinately kills the tone.
                  Chuck.
                    A 5Y3 rectifier (old production / USA made) will bring the VB+ down some and so will reduce power output significantly. But even a few watts is freakin loud in a domestic situation!
                      Huh? IMHE 6V6's need as much as twice the drive voltage as EL84's.
                        You might want to talk to the posters on 18watt.com. They have a couple of layouts there for 6v6 complements and several amp builds.
                          Yes, thanks olddawg,I'll check it out. I did use the el84's for the lightning build as per the schematic. I do have another set of 15 watt Matchless tranny's though and I would like to explore the idea of a build with 6v6's. Thanks guys for all your replies,much appreciated.
                          Chuck.
                            I stand corrected. Sorry 'bout that.
                              Well, it's different strokes more than anything. Many EL84 amps drive the grids TOO much. A swap without changing grid drive would probably yield very acceptible results going from EL84's to 6V6's. Going the other way may well be way too much drive though.
