power section fuses
  • power section fuses
    I read something recently here about fusing amps and merlin listed about 5 basic things to protect the amp.
    One was fusing both primary wires from the PT to the rectifier.
    Say my PT has 350v @ 200ma output; Should I use two 250ma fuses?
    The PT windings that supply the rectifier are secondary windings (just a small detail ;-) )
    Ideally you want the fuses to blow just at/slightly above the current draw rating of the winding.
    R.G. did a good article on this a while back (see attached .pdf)
      Most old (and new ?) power transformers gave their HT output windings with a DC load current "rating", which unfortunately does not relate directly with fuse ratings for the winding(s).
      For secondary HT fusing, the fuse rating depends on the type of filter - choke input or capacitor input. The fuse for choke input is pretty closely defined, because the rms current in the windings is closely related to the DC output current. But with capacitor input, the rms current through the fuse is a complex relation depending on circuit resistances and capacitances, and ss rectifiers introduce surge effects as well. One technique to determine fusing is to replace the fuse with a sense resistor and measure the rms sense voltage (ie. current) at full cranked output.
      You can fuse the CT or each winding arm in a typical HT configuration. The rms current of a CT will be nominally root(2) times the rating of an arm fuse. I prefer to fuse the CT for simplicity, but I guess there are some failure modes for valve rectifiers where arm fusing would have an advantage.
        haha!! There wasn't a face for "embarrass", so I still have to use the next best thing, I still qualify for that one, I think~
        Thank you so much, Tubeswell!! I'm going to read that article now!!
        Yes, trobbins!! I do have my CT fused now, but I want to learn the more complicated way next. Thank you for describing the equation between the CT and arm fuse relationships!! That helps because I know what is correct for CT fuse I'm using now.
        Yay!!
        I read R. G.'s article and understand that for my application (PT secondary wires to the rectifier), I must play the amp LONG and LOUD starting with low-value slow-blow type fuses and keep going up in value until they don't blow anymore!
          My next question is about fusing the power tubes' cathode. In my instance, with fixed bias, I have a bias checking resistor between each power tube's cathode pin and ground.
          I would use a single fuse in series between them and ground as merlin stated as adequate. His website gives no information on what values to use for this method of fusing. The hypothetical values I've seen in my research are between 250~315ma— but I don't know what the application for that recommendation.
          Has anyone actually fused their amp's cathodes in this way?
            I've put fuses in for high power amps with paralleled tubes where I want to save the output transformer more than anything else. You can estimate rms current level from the valves loadline - about 70% of peak anode current would be a reasonable lower limit for a fuse, so that if you chose the next standard fuse size up then that should give a reasonable margin on fuse rating and allow cranked 'square-wave' operation. A good idea is to parallel the fuse with a approx 10k resistor to allow the valve to go cold bias if the fuse blows, but not stress the cathode-heater if the tube isn't the problem.
              This thread will give you an idea of the current in an output tube of a 5F6A re-issue.
              http://music-electronics-forum.com/t28786/
                Great link, loudthud!! Those traces are wild!
                Wow!! You guys are great! Thank you trobbins and loudthud!!
                  Various manufacturers have done this, the first one that comes to mind is Marshall. Have a look at JCM900 schematics to see their method and fuse values. They even have a LED to show you the fuse has blown, in case you don't notice .
                    Ya, I'd heard about something like that mentioned, only I didn't know which one-G!! I'm gonna study that right away~ Thank you for the telling me which model had that feature!!
                    I checked—
                    It showed the EL34 tube-pair's cathode lead to ground connected to a 500ma (type not stated) fuse in parallel with 100k R. The resistor is connected to an LED, but I can't read its label… "R/A 5ma(?)".
                    The schematic then shows the paralleled fuse and resistor/LED going to the ground-buss. Dang, I wish I could read what kind of LED, but it's too fuzzy to tell!
                    Thank you g-one— the values shown here for the fuse and resistor in parallel that trobbins had mentioned earlier helps!
                      The fuses Marshall uses here are definitely slow-blow type. The type of LED shouldn't matter, they are only in use when the fuse has blown. Whatever will light up with the 100K in series should be fine.
                        Cool!! Thank you for filling in those blanks, g-one!!
                          Sorry to muddy the waters but I don't see the need for slow blow fuses in the power tube cathodes; there's nothing there which has switch on surges etc, so better to use regular F quick blow, that will respond immediatley to tube shorts.
                          Also I found 100k resistors too high a value to light the LED; 10k was better.
                          Pete
                            Hi Pete, could you please tell me which LED you used? That would be nice to know!
                            Mouser had some of those, which ones should I try, trobbins?
                              They were likely a bog standard radiospares red 5mm type, possibly a low current variety.
                              It was on a vox v125 which I repaired and made a bit more robust a few years ago, so I used 4 of a 5 pack, and probably haven't keep the pack with the part #.
                              I don't think the LED spec is critical. I seem to remember that the EL34 cathodes sat at about 30V with the fuse open, but that may be a lot higher in the case of a tube with some kind of fault.
                              Pete.
