Oh stop it JM. It is a scientific fact that carbon comp resistors generate second harmonic distortion. There is a plot of it in The Art Of Electronics.
At the signal level seen at the plate of a tube amplifying stage, the effect should amount to a few percent distortion, which could well be audible. I'm not sure why Loudthud's experiment didn't show it up. Here are some possibilities:
The distortion from the tube itself swamped it.
The noise and distortion from the scope front end swamped it. (Scopes are designed for high bandwidth, not low distortion.)
The signal wasn't big enough.
The resistors were too good. Maybe some resistor maker figured out a way to reduce the voltage coefficient. What was the tolerance band? If there was even such a thing as a 1% carbon comp, then it would need special treatment to stay within its tolerance band at the voltage corresponding to rated dissipation.
The "carbon comp" resistor wasn't really a carbon comp.![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
I personally prefer metal film and metal oxide resistors for their lower noise and higher reliability. I think my circuits sound fine with them.
I once joked that metal film resistors would make the amp sound "metallic" but it turned out that a few respected boutique amp builders actually thought I was serious and agreed.
I think there's a synaesthetic thing going on, where people imagine what the material would sound like when tapped, and then assume that the flow of electrons through it somehow brings out that same sound. This is not at all true in general.
