Me again.
I could use some help choosing transformers for an Ampeg B-15NC build. I would like to give Magnetic Components a try. I inquired and got a response from the engineer who drew up the drawings. (I like that!). He says they don't have exact replacements, but offered me these.
PT: http://www.classictone.net/40-18094.pdf
OT: http://www.classictone.net/40-18064.pdf
B-15NC: The Unofficial Ampeg Page
The PT with a 5AR4 shows B+ of 422v, where the schematic shows 440v. Is this enough of a difference to make a difference? I think this would have me expect to see voltages about 5% lower than called for, but if going by the Fender +/- 20% standard, shouldn't this be OK? And I plan to only have one channel, eliminating a 6SL7 tube, will this put less of a load on the PS and help to bring voltages up a bit?
The OT, I have no real idea how to spec the primary. If I decide to run an extension jack, which would be the prefered choice 4 or 8 ohm tap, and why? I notice Ampeg used 8 and 16 ohm.
On the schematic, the K on the output cathodes, does that go to the K on the hum balance? If so, is that a good idea, or should I just use the CT on the filament winding?
Thanks guys.
Thanks guys.
