What should I add to this custom amp?
  • What should I add to this custom amp?
    I'm all for leaving a good amp alone.. The only problem is that this amp I put together, which takes bits from the magnatone 213 and fender 5e3 (along with some other things I like), has an open spot on the front for a switch or pot.. I feel like I need to put something in there just for appearances sake.. And I feel like there must be something I could add that would give the amp a bit more versatility.
    Here's a schematic:
    http://s15.postimg.org/im2tjzcnd/Bogen_Conversion.jpg
    The Tone control is very different to anything I've used before, but it gives me a ton of tonal range. The amp as also quite low power so I have no need for a master volume..
    Any ideas on what I could add as a switchable or potentiometer based control?
    Why don't you put a 9Vdc output jack on it?
      I'm not sure what I'd do with that.. Are you thing for pedal power or something like that?
        Yes. It's a very rare amp that doesn't get used with some kind of pedal. Having 9Vdc coming out of the amp just makes pedal use easier.
        I'm not sure why - except history - modern amps don't have 9Vdc out of all amps.
          Which polarity?
