I have a champ build going on and I wonder how to test whether the OT is good. Had problems with arcing on the power tube between pin 2 and pin 3. The 470 ohm cap was damaged, dont know if that caused the problem - this cap
Want to be sure the OT is good. Its a mojotone OT - has one blue wire wiring diagram shows to B+ and one red wire for power tube and only one yellow wire on the output side. The yellow wire shows continuity to ground - is this normal? Also the mojo drawing seems to show both the yellow wire from OT and white wire from the board (as in the attached drawing) both wired to the tipe of the speaker jack. Its a lousy drawing but that seems to be what it shows.
Help please
Help please
