So after looking at the JJ data sheet, and seeing that pin 1 is NOT marked with i.c. (or used for any other purpose) I decided to use that pin to land the screen resistor. Running from pin 9 to 1, what could be more natural? THEN I happened to look at a Phillips data sheet that indicates i.c. for pin 1.
... and so it snowballs. A review of querys and posts - including one Steve A. started back in 2000 - leaves me guessing if ANY pins are routinely used as tie points. Is using the base of an EL84 as a terminal strip strictly forbidden? Who has tried and lived to tell?
