Trying to find specs on a Fender Deluxe transformer 0027668000
  • Trying to find specs on a Fender Deluxe transformer 0027668000
    Google has failed me...
    Anyone know where I could find specs? I have one of these and want to know if I can use it for a frankenproject.
    Thanks
    -John
    Not for what we commonly call a Deluxe, but for the solid state Deluxe 112, also Roc Pro 1000.
    Has only one secondary winding, which is used to produce +/-40V in the Roc Pro. Not sure the current capability, but the Roc Pro claims about 100W power output into 4 ohm load.
      Thanks.
      Anyone want it?
        Originally posted by jmardy View Post
        Thanks.
        Anyone want it?
        Still have that transformer. I'm looking for one. Thanks
          Thanks
          -John
          Remember that is manufacturer's part number, so there will be no actual specs to go with it. You need to track down what amp it was for and then look at the amp info, schematics, etc. and figure it out.
          Another example might be 606 532 on the tranny. The 606 tells you it's a Schumacher, the 5 tells you the last number of the year it was made and the 32 tells you it was the 32nd week of that year. I know of no transformers that have any spec. info stamped on it, just OEM numbers and the EIA code, the 606 532
          Turn it up so that everything is louder than everything else.
            Should read: Still have that transformer?? I'm (still) looking to one. - Thanks
              That user hasn't been active in over 1.5 years. Maybe sending a PM would get his attention?
                Tried that too... will see what happens. No urgency, just would like to convert a FM212R amp from 220v to 120v. Using an external step down transformer for now.
                  Fender Power Transformer, Roc Pro 1000
                    Nice, Ty! I figured if jmardy still had his (hers), maybe i could save a buck. But for $44 new... hard to beat.
