After a few failed attempts I figured I'd build this amp by section and see where I'm going wrong. My goal is a Princeton 6G2 base model with a few tweaks after I get the darned thing running.
Using parts I have on hand, I paired the two 16/475 caps in series (pre-standby) which I know only gives me 8uf there, but this is a test so the capacitance value shouldn't be all that important right now. However, when I turned this on it immediately popped the 470 ohm sandstone resistor. I tried a second one thinking the first one might have been defective and it popped that one too.
Is 505v too much for that type of resistor? And why am I getting 505v (DC) instead of mid-high 400v with a 5Y3? I realize this is unloaded but my pre-rectifier voltage is only 373v per leg with the CT going to ground so it seems a bit high.
