Okay, right off the bat, I'm a noob at tubes. Built a few small SS 'practice' amps, but nothing with tubes. I have worked with high voltage before (AC mostly, in my past as a 'spark-trician') so I know about electrical safety. Yes, I understand that the circuits can 'store' some energy so they need to be bled down.
But I've aquired a small PA/phono amp (it has two inputs) to use as a Frankenstein learning project. I know I need to replace at least one pot as it is bad (it serves as the on/off switch as well as the tone control of all things). But the tubes it uses are 12AX7 (pre-amp, split to pre amp each of the inputs separately), 6AQ5 (which I believe is similar to the 6V6), and a 6X4 (I think this is the rectifier). So it has a bit of potential by using both stages of the 12AX7 to be a bit 'Champy'. Main issue is the power tranny. I believe it only puts out 250V, so to replicate a circuit like a 5E3 (or even an AA764) I believe I'd need to recalculate the resistor values or change the tranny.
But my objective is to take a small step into the pool and learn the circuit. So, could this thing work (function, but not have to sound like a Champ, but be passable for my extremely limited playing ability)? Comments? Suggestions? Flames?
