My unfinished projects !
Tags: None
I have been saying this for a while... but this is the year that I will work on mine! I have a Crate Blue Voodoo (BV120) that will be a donor for a test jig. I will use the power supply, tube sockets, etc and have a means of testing preamp and output tubes under load. I think I'll disconnect the existing output stage and maybe convert that to a single socket -single tube. If the voltages are right, I was thinking of using a smaller output transformer, something like a 15 watt and rigging up a class A. I want to test one tube at a time... under some type of load.
This site has plenty of threads about Tube Checkers serving as a quick and dirty, go / no-go check. The best way to test a tube is in a circuit. And that is the project I want to build... a test jig that will measure two sides of a 12ax7, 12au7, output tubes, etc. So I am thinking I will have a proto board of some type where I can swap out different tubes. Of course, proper voltages and other circuitry are a must...
Just a nutty idea....It's not just an amp, it's an adventure!
Looks like my room... 16 amps in various condition, from fully functional to chassis-trannies-sockets. Everything else got tossed! But I only work on one at a time, so this former-Thor gets done with dehumming first. Then gain control...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
That's a very tidy bench compared to my world.
My list of unfinished projects include an Orange Bass Terror pre amp in a vintage radio case, various pieces of test equipment. One thing I did finish just the other day was a valve tester. It's a Sussex valve tester (similar to an Avo CT160) based on the design at vintage-radio.net and whilst I don't think I will use it as much as I originally thought the process of building it was really interesting and I learnt a lot.
I'd really like to see some other amp caves. If you have a pic please share
Originally posted by J M Fahey View PostJust curious (always learning) , can you post the Terror Bass schematic ?
Ok... I will call this one DONE - the 4 in 1 bias box. This box uses 4 probes that measure Plate Voltage and Cathode Current.
In reading other MEF posts (and thanks again mates), the message I got was "reading Cathode current alone doesn't tell the entire story... you need to read the plate voltages too." So why buy a kit where you can only read Cathode current or the more expensive kits where you can read the plate voltage on just one of four tubes? That is where the Bias Scout is handy. It will give you both.
Using the TubeDepot Bias Scout Kit (4 of them), I ran the ends into a project box, added a Rotary switch (you need a 4 position, double pole, Break Before Make) all going into a SPDT with Center Off, and that goes to a set of banana leads.
The assembly off the tube sockets can be tricky. You need to take your time. I found other ways to stuff the resistors in the socket and relieve stress on the resistor leads. Anyway... about $100 later, I have my kit ready for use.
One flip of the switch and you measure the Plate Voltage. The other side measures Cathode Current. Follow the directions on the probe kit for that assembly. Beyond that, it's easy to connect the rotary switch and SPDT. One side selects the Current reading, the other side selects the Voltage reading.
If you cannot find a 4 position rotary switch, you can buy a 6 position and leave 2 slots unused.
Take your time, fun project, very useful tool. This comes in handy of you want to check the tube bias and not remove the entire chassis from the cabinet. You can probably find a YouTube video where a guy builds something similar.
Good luck!!It's not just an amp, it's an adventure!
amp cave of southbound suarez aka dugdiamond
Originally posted by swingarm View PostI'd really like to see some other amp caves. If you have a pic please sharePhineus J. Whoopy, you are the greatest! May just get one more peek at that three dimensional blackboard please?
"I feel your pain..."
My furniture consists of a bed, dresser, and uncountable vintage amps, chassis, parts, and amp-related detritus... I think I counted 16, in various states from complete & working to "stripped for later." 5 are for sale,so that might help...
Justin
Sixteen working amps yet none of them fully enclosed or quite road worthy. All projects!
Honestly last week it was eighteen, we actually got one one the road and another into the pawnshop to make for some up front money to complete a build for a top notch customer that has wayyy too much faith in me! But that is another story as now I have three more projects and now stand at sixteen again as I wrenched two more out the door..... someone double check my math..... Did an all nighter on a deluxe reverb and am fighting my diabetic blood sugar here today at the shop!Phineus J. Whoopy, you are the greatest! May just get one more peek at that three dimensional blackboard please?
