I'm looking for the source of the requirements for the Safety Earth Ground wire that goes from the ground pin of an IEC power inlet connector to the chassis.
Most equipment uses a green or green/yellow wire, which is connected to a separate bolt than the star ground(s), and has a little Earth ground sticker next to it.
(Green wire from IEC connector to chassis in this pic from Ampmaker)
I found the reference for the connector is IEC 60320-1, and UL 498 (as well as IEEE Std 1100) have requirements for grounding and wiring, but I can't find the specific requirements to use the green or green/yellow wires, or to use a separate chassis connection.
Do any of you have anything more specific?
Thanks!
Thanks!
