power transformer bad?
  • power transformer bad?
    I apologize for having posted in the wrong place. I'm debugging my first build, a jcm800. My question is should it take a minute or two for the voltage to reach 500 Vdc. This is after rectifier but before stand-by. Going through 100uf capacitor before stanf-by. Thanks for the help, Greg
    Very curious that it would take a minute or two to come up to full voltage, it's usually more or less instant, under a second. You don't have a lightbulb current limiter on the AC line? That or something like it would result in a slow chargeup.
      Nope. Just the rectifier and the cap
        Plus when I take it off stand-by the voltage drops unless the 50uf caps are disconnected
          Measuring the AC on the transformer secondary, how long does it take to reach it's max output?
            382 vac instantly
              Then it can hardly be a bad transformer. Can you show or draw up a quick schematic of how you have the circuit wired?
                Caps in backwards.
                  Pretty sure its correct. The schematic I'm using is a 2204 by Marc huss. Only difference between it and mine is stand-by placement. Mine is between cap and fuse. Schematic between transformer and rectifier
                    Could switch placement be the answer?
                      Possibly a grounding issue? Do the caps and the PT center taps share a ground as shown in the schematic? Also can you verify this is the schematic you are working from?
                      http://mhuss.com/MyJCM/JCM800_2204.pdf
                        Yep that's it.
                          No the caps and pt don't share a ground
                            Are they both grounded?
                              Yes, that's what I was asking. I meant electrically- not physically. I was surmising that maybe the voltage was 'floating' up because of a missing ground and that's why it took so long to get there.
