Originally posted by nosaj
Originally posted by g1
View Post
If you have access to a variable bench supply then you could experiment with that first and determine if you get results you like before you build a custom field coil supply. For information on building a power supply I’d Google “Experimenter’s power supply” or similar. The problem is that most hits are for low voltage supplies. You may want to look in older literature such as the Radio Armature’s Handbook old Popular Electronics magazines and the like. Edit: Here is one link http://www.eleccircuit.com/0-70-volt...-power-supply/
I don’t know your resources and capabilities but another approach is to cobble together a 70VDC supply our of junk box parts and then turn it down with a Variac at the line side or reduce the voltage to the field coil by inserting dropping resistors
Hope this helps or at least kicks off a discussion for others to add their ideas. I would think that we are not the first to think of using an old field coil speaker this way. There must be discussions out there on the same topic.
Cheers,
Tom
