In replicating a transformer with the original construction and windings, then often the line voltage in the US is higher now than it was back in the day and output voltages are higher. Even classic amps suffer from over-voltage and there are regular postings here illustrating that problem. Here in the UK we have higher voltage at different times and in different regions. I measured 258v a couple of days ago. Plus, we're getting stung with the EU harmonization scheme where primaries are actually wound for 230v - even though many are marked for 240v. Fender amps come into this country wired for 230v. Put that on a supply that averages almost 250v and the B+ is way higher than it should be.
I can't recall in recent years buying a PT were the voltages weren't much higher than the nominal ratings.
Then there's the consideration of using what you already have.
