A year and a half ago I started building a Shiva pre/Hot Cat 30 power amp and then when I was close to finishing it I had to move and then didn't have a workshop to tinker in ![Frown](https://music-electronics-forum.com/core/images/smilies/frown.png)
Well that changed recently and I now have a workshop again so I've been finishing up the things that I had to abandon and this was high up on the list. I've stuck all the pictures and information in an Imgur album as that seems to best way to document these things:
Shiva/Hot Cat 30
I fired it up yesterday and it worked fine but the voltages are a bit too high for a 3k25 primary OT as I was seeing over 400VDC on the plates and screens. My first thought it to try and shave 30V off by putting a string of 3 5W 10V Zener diodes between the -ve and ground of the bridge rectifier. The OT has a 4k primary option too so I think I'll switch to this to avoid over dissipation. I think that I should be safe with 15W of Zener dissipation to drop that voltage. The PT is rated for 370 mA so if I was to drop 30V at that current the dissipation would be 11.1W so I have a bit of a margin. I can't see the amp pulling anywhere near that much so I guess I should be okay. If I'm waaay off the mark here could someone please let me know
Shiva/Hot Cat 30
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
