Does anyone know of a 2-pole, triple throw toggle switch with On-Off-On function rated for 350 volts or more AC?
I'm getting a power transformer that has two sets of HV secondaries:
330-0-330
355-0-355
Since I don't need a Ground switch, I thought I could use that hole in my 5E3 chassis to switch between the lower and higher PT secondary windings. However, I haven't been able to find a suitable switch that doesn't cost a small fortune.
Please refer to attached power supply schematic. AC voltage rating is serious constraint for my switch. Would it help to have four diodes instead of two and have the switch between the diodes and the rectifier tube? (instead of between the power transformer and the diodes) My thought is that the switch would be handling "DC" instead of "AC" with four diodes.
BTW the diodes are there as protection in case of rectifier tube failure - see "Immortal Amp Mods" #1.
Any ideas or suggestions?
It doesn't have to be a toggle switch. Rotary or rocker would work. I guess On-On (On-none-On) function would work, but it would need to be "break then make" connection unless I'm mistaken.
Chip
330-0-330
355-0-355
Chip
