This is my recently finished second build - I've been obsessed with self-split dual triode output micro amps for a while now, and last year I built a 12AT7 Firefly in a pedal enclosure that I've been trying different preamp arrangements in.
I wanted to try something with more gain and a full tone stack, and enough power to be able to put it to good use, because the 12AT7 / 12AU7 output just can't drive enough bass to sound mean.
It is a JCM800 preamp tweaked very slightly (to my own tastes) feeding an ECC99 dual triode in self-split cathode biased push pull configuration with no phase inverter. The output transformer is a 22.5k plate-to-plate replacement part for a Blackstar HT-5, which runs the same power tube, and the power transformer is a replacement part for a Fender Excelsior. It turns out it's a bit excessive and it runs with 500v on the plate, but I've been stress testing it for the past week and the JJ ECC99 I've got in it does not seem to mind one bit. It doesn't have a center tap for the 6.3v heater winding, so it had a pretty bad hum until I made a virtual center tap with 110 ohms from each side of the winding to ground. At the same time I was adding that bit I replaced the power LED with a lamp.
I'm kind of blown away by how well this thing turned out, but I leaned heavily on robrob's site (his Bassman Micro and Deluxe Micro designs, his JCM800 explainer, and his bias calculator) and I guess with those resources plus the experience of having built a self-split mini head before I was equipped to pull it off.
Guts:
Schem:
Sound clips:
1
2
