So i replaced the blown resistor & replaced 3 of the 8 belton tube sockets that hot glue melted into them causing this Amp to have a fairly loud hum .
Now that the amp is up & & in good working condition .I've heard some say it's made in china But I can not find on it anywhere saying made in china .I't has quality parts like Belton tube sockets ,Belton reverb tank & some other quality parts . I will say it is a pretty versatile amp 3 channels ,reverb ,2 master controls ,separate EQ's on each channels ,fx loop ... I don't think absolutely shines at any one tone( Class A output what ever that means more in the vox vibe ) .kind of sterile maybe .I've tried to sell it locally but only had offers for a couple of hundred bucks .
which I'd rather keep or scrap & salvage the 4 el84's & 4 12ax7's .& maybe strip her down & use the trannys ( I don't know what brand of trannys ) & chassis & cab switches to build some sort of 40 watter using a turret board .I not totally sure if i would even go the el84 tube configuration .I have some new sovtek 5881's that a buddy gave to me . going with 2 of the 5881's (modifying the chassis for the keyed 8 pin tube socket will be fine & covering whats not used) should work for a simple tweed or marshall build .I would consider adding an fx loop & the utilizing the reverb circuit the it is probably not an absolute need .
Feel free to comment .
