This picks up on a conversation which started in Uneumann's thread "Help with chassis" found here:
http://music-electronics-forum.com/t43010/
I wanted to post some of the updates as I progress through a build and share some of the things I've learned (and am learning) -– what has paid off and things I would do differently. I had posted some images I'd taken of different stages of the chassis and left off talking about the different techniques for cutting the square hole needed for an IEC. I came up with a way of creating the mounting hole using a drill and file which worked out way quicker than I had anticipated. This works very well for those who don't have access to a punch or mill. This is the result:
![Click image for larger version
Name: IEC jack Mounting holes.jpg
To Keep the chassis clean and simplify the physical layout, I opted to use some insulated turret terminals with a threaded base. This required tapping some holes in the chassis. With the proper tools (and a little patience to make sure to locate them and wait for them), this ended up being a painless task.
Here are a couple of pictures of the terminals and tapping 2-56 threads:
Name: Tapping aluminum for threaded terminals.jpg
Name: Tapping aluminum for threaded terminals2.jpg
Up to this point the all of the holes were falling withing really close tolerances to the drawing I had created. All of the planning was really paying off... until I got impatient. I made a DUMB-ass mistake.
I'm have to work in the morning, so I'm crashing. But, I'll tell you about it later and ask for some advice on the best way to deal with it.
