Hello. I tried to put a volume pot in front of the pi stage from image and have a issue to put the potentiometer to minimum level position. When turn off the pot at around 10 ohm resistance to ground the stage start to oscillate. I tried a series resistance in series with the input cap. that solved the problem to close the pot at minimum level but now have instability in an other position of potentiometer The oscillation is sort of buzzing sound. What sort of issue could be and how can be cured.please? It is a grounding problem maybe? Thanks.
[ATTACH=CONFIG]42004[/ATTACH
