So, I just got back and had a buddy come over while we powered up my build for the first time.
First things first, I used a 25W incandescent limiter to take some readings of the secondary AC and DC voltages with the tubes pulled to take some no load readings on my secondaries. (roughly 1mA resistive max load).
Using a true RMS meter, I first tested the mains voltage, which read about 118VAC. After a great start, it turns out that was the only measurement that gave me the voltage I expected. My secondary voltages are troublesome. The no load AC voltages measured pretty much exactly what I designed them to be under full drive conditions.
The secondary which supplies the main amplifier is spec'd for 245-0-245 under a load of 150mA. I was getting 241VAC to center tap from each leg and I turned to my friend and said "bullshit the regulation is that good". I told him I expected to see around 252V-260V.
Also, the other secondary supply was spec'd for 100-0-100V at 100mA for my +/- voltages. Under no load I was getting about +97VDC and -98VDC (which totally f-ed my bias calculations).
I then switched to a 60W bulb and put in my put my preamp tubes and driver in, and set the grid voltage for the output tubes before installing them. But the DC was well under 300V, and my secondary fuses on both legs blew open. I suspect they may have fell victim to repeated in rush when switching power on and off. They are 200mA fast blow 2AG.
What going on do you think? Just a dud power transformer? I'm thinking of calling the manufacturer, but I want to do this again and make sure I get the same figures to be sure. But the fuses blew because of something and I want to find out why before I make any decisions about where to go from here. You know, I really never anticipated having to replace a mains transformer for any other reason than destroying it somehow.
Funny thing is, I used to bitch about designers who soldered leaded fuses in a circuit because it... well, because its a pain in the ass. That's why. But, I decided to call an audible towards the end of the build and solder these particular fuses in because I was worried about the littelfuse fuse holders being too brittle. So, I soldered those fuses to the board. Figures those were the ones to go!
