Heya
I just finished building my first tube amp, a JCM 800 2204 and it plays like a dream.
and now i want to build a second amp!
I was thinking of building a Marshall Major 200w amp because John frusciante plays one too. I read they are a bit of a troublesome amps, blowing up tubes etc, but have new freshly build majors the same kind of problems?
That aside.
I have found this schematic of a Major. And did some research.
And ofcourse some questions came up. So here they come.
Ill start at the power stage.
- At the rectifier. Are those caps in front of it 0,22? It's a bit blurry there.
- Still at the rectifier, wich diodes are used? and how many? (8x A10010?)
- Bias stage (or however its called..) Are those 2 diodes 10D8?, the 3k pot is that the bias potmeter?
- Where do i get 375uF caps? I cant find them in the intenet shops near me. (TAD, Verelec, Tubetown, Musikding) Or can i maybe put 2 caps parralel?
- Screen Resistors: Can i use 1k instead of 250ohm. Same problem as the 375 caps, cant find them at the internet shops. But if i do does it effect to the sound?
- Anything else i need to know?
That's it, sorry for my bad english but i hope you understand.
That aside.
