Standby sw wirinq question
Last edited by catalin gramada; 10-18-2017, 01:57 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
No, didn.t works no matter how is wired. Do You have any ideea why? Just power stage was connected so any possible grounding issues are excluded. snubbering network over contacts just help me to get rid of popping when is switched off but pops when switched on. I have not ideea how can diagnose where the source of the problem is. Share some help, please ? ThanksLast edited by catalin gramada; 10-18-2017, 01:42 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
However you switch it, it pops because the voltage changes instantly from something to something else.
Why do you consider this a problem? I assume you are not flipping the standby switch while playing.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostHowever you switch it, it pops because the voltage changes instantly from something to something else.
Why do you consider this a problem? I assume you are not flipping the standby switch while playing.Last edited by catalin gramada; 10-18-2017, 02:17 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I do. Not every amp pops, but many do.
If an amp pops when you switch channels, I look for a solution. If an amp pops when you turn it on, I don't even notice.Education is what you're left with after you have forgotten what you have learned.
That can be true for me aso. I worked at this amp last week and quick wired the switch temporary without snuber for a test and didn.t notice the noise. Trying to finish I noticed now . Damn..I don.t remember if it pops before or not...
edit: anyhow is irelevant as cannot be sure if I waiting to heat the tubes till starts to conduct..Last edited by catalin gramada; 10-18-2017, 03:31 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I had a SS Marshall which had a REALLY loud pop, more of a bang, it actually made me nervous when I knew I had to switch it off (on wasnt so bad - making vs braking) so I stuck a couple of high value caps across the switch terminals and that sorted it right out. I was a bit reluctant as it seemed like bad practice in case they fail, but there seems to be plenty of examples of people doing this and you should probably have it unplugged before you go poking around either way! There are caps you can buy rated to fail open which would probably be appropriate here
1) the top and bottom circuits are exactly the same, so you shouldnīt expect any functional difference.
2) the wiring shown is wrong, and can be dangerous because it can give you a false sense of security: the bottom capacitor is switched ON-OFF but the top one is *always* charged to 280V DC.
You might think: "I switched AC standby OFF, now itīs safe to work" .... it is not.
3) a minor point: voltage ratios between caps are 3:2 , so bleeder resistors should also be roughly 3:2 ; say 220k on top, 330k on bottom. Not a big deal but since we are analyzing the circuit
4) yaībuilding a Hiwatt?
5) for proper standby action either use a double switch "DPST"
, each half switching one HV AC secondary, or each half switching one HV rail.
Personally I would not use standby, not sure what HiWatt did about it, but of course itīs your choice.Juan Manuel Fahey
Originally posted by J M Fahey View Post1) the top and bottom circuits are exactly the same, so you shouldnīt expect any functional difference.
I can use a double switch and calculate the bleeder resistors values in respect with current over each caps. Do you think it will stop the annoing "pop" ? I thinking more to put a "X" type cap over secondary...
I still consider those "pop" as a transient, a disfunction but have not ideea how to identify where coming from..Last edited by catalin gramada; 10-19-2017, 05:49 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by alexradium View Posttry a 47/100k in parallel with the switch."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
If you must cure it, then FIND OUT where it is coming from. Do not assume the standby switch is the problem. Leave the standby on, and just cycle the power switch on. Does it still pop that way? Same trick for turn off pops: just pull the plug from the wall outlet instead of turning off the switch. Does it still pop?Education is what you're left with after you have forgotten what you have learned.
Originally posted by J M Fahey View PostYou might think: "I switched AC standby OFF, now itīs safe to work" .... it is not.Last edited by catalin gramada; 10-19-2017, 06:23 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
That is the problem: No one has to be qualified. On this forum we have some very experienced techs, and we have guys who are lifting a volt meter for the first time. None of them had to get qualified to jump into an amp.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostIf you must cure it, then FIND OUT where it is coming from. Do not assume the standby switch is the problem. Leave the standby on, and just cycle the power switch on. Does it still pop that way? Same trick for turn off pops: just pull the plug from the wall outlet instead of turning off the switch. Does it still pop?
late: I will wire a separate transformer for bias voltage and leave the caps to discharge a little more if it have any sense...
No problems with stb.sw tured off. It was think sort of inductive coupling somewhere but was cured with snuber network. Anyhow was diferent manifestation. when turned off "the popping" had higher pitch like arcing. This turned on "pop" is a "muffled thump"-hope understand my representationLast edited by catalin gramada; 10-19-2017, 08:05 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
