Hi All
Working on adding reverb to a deluxe build that didn't have it. I noticed that the 12AT7 first reverb tube (the send tube) plate is powered from the first filter cap, right after the choke (and before any dropping resistor), marked "B" on the AB763 schematic.
On the old schematics found online, the voltage at this point is marked 410v, but I know in my amp its much higher, probably over 430 or 440v.
After getting the additional tubes for the reverb, I noticed on the data sheet for Electro Harmonix 12AT7 max plate voltage 330v. <big frown> Its not even in the ballpark. So I started looking around at various tubes online and haven't found one that has a max plate that high.
Then I noticed that every other tube in this amp, and most any other amp schematic I could find, have a 100k resistor just before the plate feed, but in this schematic, there is no resistor between point B on the power supply, and the transformer primary lead.
Can someone recommend a new tube for this spot in the amp? With new production tubes, do you guys put additional components in to drop the voltage to this tube on a replacement?
As another aside, Ive seen 'complete tube set', some have JJ's in this spot, and their data sheet says 300v max!
Thanks!
Mike
Thanks!
Mike
