Most of the kits run most wiring to the bottom of the turret or eyelet. The mechanical connection isn't very good there.
Ive seen a few builds/kits like this, that run the wiring up through a hole near the eyelet/turret, then solder to the top of the board.
This puts an extra turn in the wire, where it has to go backwards, to the hole, down, then turn back towards the socket pin (or whatever the otehr end is soldered to).
Would these extra bends in the wiring cause more problems than having the wire run out the bottom of the turret or eyelet?
Thanks.
MP
Thanks.
MP
