I had a flick round and couldn't see any kind of official 'make your introductions here' thread.
This is, therefore, me saying hello:
Hello!
I'm a bassist and guitarist from Europe. I've made a couple of effects pedals, but never anything particularly complicated. Recently, I decided to start playing bass at a level above the '15W Behringer Combo' level, but I couldn't find what I wanted in a commercial high-end bass amp; the closest was probably something like the Fender Bassman 100T, but they're expensive, not that well made and far too full of digital gumphf for my tastes. So, after spending some time considering older model bassmans, a young man named 'Woody' convinced me that what I need is a 1960 6G14 Fender Showman amp, a quad 6L6GC brownface design. The problem is; the £4000 it would cost me to get one of these in Europe (in the unlikely event I actually found one) would make it something I could never manage to buy, much less take to gigs and stand a pint of diet soda on it (I'm kidding about that last part... mostly). So; I reached the obvious inevitable conclusion, and I'm building my first valve amp.
I'm making a few modifications compared to the original 1960 Fender schematic:
Finally, I'm building the whole thing in a reproduction Blackface Twin Reverb chassis. Brownface Showman chassis' and cabinets are not a thing that can be bought, and this seemed the efficient way to get around that; because of this I had the extra mounting points to add the Heater adjustment switch and pot, the Bias pot and the extra speaker outputs. I also have an extra pot, and a DPDT On-On slide switch on each channel, which I'm populating but leaving unconnected for the time being, as 'upgrade space' for doing any additional mods later. Conveniently, I was able to find a company in the US that would precut and press eyelet boards for basically any Fender amp schematic, so most of the 'mechanical' work is done, and I can worry about the electronic side alone for this first build.
As for where I'm at with it, I've made my tweaks to the schematic, assembled a parts list with sources. Of these, I have about a third, with the remainder of the passives, potentiometers and connective parts arriving around the end of next week. After that, all that remains are the decorative parts (cabinets, custom faceplates, etc), the transformers and the power tubes. You can probably guess why those components were left till last; i don't want to damage them while messing around with the rest of the build, and they account for just shy of 70% of the cost of the amp; if for any reason this all goes downhill, I have lost a relatively small amount - unless it's after purchasing the cabinet and transformers.
In any case, wish me luck!
Hello!
- Since I live in a country where every socket is earthed by law, I'm stripping out the ground switch and using a 3-wire plug, naturally.
- I'm also using a slightly different preamp tube with a 9AJ pin-out, and I'm wiring my tube sockets for a panel switch that swaps the pre-amp sockets between 9AJ and 9A wiring. This way I can do tube swaps between 'specification' 7025 tubes, and the kind I'm using, without having to resort to a soldering iron.
- My nice European-voltage Power Transformer doesn't have a centre-tap, so I'm adding a Silverface-style hum balance pot as an artificial centre tap, elevated to 80VDC to reduce the Vhk stress on the pre-amp tubes in cathode follower and phase inverter positions; I don't want to be replacing them often, after all.
- I'm adding panel-mounted bias adjustment, also following the design of the Silverface amps, because it seems obvious.
- I'm using a reproduction Brownface Twin output transformer to get the sound of the oversize Showman PT, but with multiple taps so I can run different speaker configurations.
