Hello all,
I am planning to build myself a two channel preamp pedal. It will have two 12AX7’s. The pedal will be fed with 12VDC and I will try to use a step up booster for the B+.
My problem is the grounding.. The preamp could be grounded with an instrument cable, when it is connected to an amp. But what if I am using the preamp with a cab simulation and a portable headphone amp? I surely could ground the device separately (and maybe add a ground lift switch on the outputs), which the commercial producers don’t do.
How do the commercial producers get away with that safety issue? Am I missing something here?
Thanks,
Evren
Thanks,
Evren
