Lacing
  • Lacing
    Just curious of those that build amps how many of you employ lacing like in the older equipment?
    And if you do what do you use(I've used Dental floss the minty stuff)
    And what method of lacing do you use?
    nosaj
    Not in amps per se, but I've done some cable harness lacing.
    Never had to buy the waxed string/cord because I got it from dad's workshop.
    But something like this is what would typically be used: https://www.amazon.com/WAXED-LACING-.../dp/B00IYOW2ZU
    I don't know if the waxed cord sold for beading (which you can probably pick up at any craft store) would be a good substitute - but probably at least as good as mint dental floss!
    You can find some lacing demos on Youtube.
    -rb
    DON'T FEED THE TROLLS!
      -rb
      Yes but you could always say it's Minty Fresh!
      It just popped into my mind so I thought I'd ask if anyone did it.
      nosaj
        Most of the time I've seen anything comparable it's with zip ties...
        Justin
          What about wire wrapping? I saw some in a thomas organ and the connections were much better than I expected for no solder.
          nosaj
            nosaj
            Lacing is a very old trade craft.
            It is used by the ton in telephone offices.
            It was used a lot in old commercial equipment, radios, etc.
            I have personally used in my 42 year telecomm career, thousands of rolls.
            This is what is used by th ton all over the country.
            T
            Terry
              Lacing is very old trade craft.
              T
              Do you find yourself using the technique at home?
              Another thing that always intrigued me was the way electricians wrap their extension cords.
              nosaj
                nosaj
                Yes, I still use it around the house, and around the shop.
                I had calluses on the bottom of both little fingers, until about 5 years after retirement.
                Here's a few of the ways you can secure wire and cable.
                http://www.dairiki.org/hammond/cable-lacing-howto/
                I will try to find some of the handbooks, we used to use.
                T
                Terry
                  What about it? It used to be the standard method for prototyping digital circuits, and as you've seen, sometimes even for production wiring.
                  It requires special sockets or individual pins with square posts. Typically 30-ga kynar insulated wire. Special wire stripper and gun or hand tool to do the wrapping.
                  I used to have all that stuff, but gave it away years ago. Wire wrap equipment is still available, but the prices are crazy. Over $17 for a wire wrap hand tool?
                  At a place I worked for in the 80's, we had an old wire wrapping machine- kind of like a vertical plotter.
                  You entered a point-to-point wiring list, and the machine would move the gun from pin to pin (the operator still had to do the actual wrapping).
                  -rb
                  Wikipedia to the rescue.
                  https://en.wikipedia.org/wiki/Wire_wrap
                    -rb
                    Just curious if anyone used it also for prototyping .
                    nosaj
                      Just curious if anyone used it also for prototyping.
                      I used to use it for prototyping digital & low-power analog (like stomp boxes). It can get rats-nesty if you don't watch out....
                        I've been using lacing cord for decades, though in the form of spot-ties (clove hitch), and not the continual run as seen in a lot of European recording consoles and older Asian equipment. It's essential for bundles of cables that need to be run thru conduits that would have the potential to hang up on obstructions if bundled with cable tie wraps. It takes longer to apply, at least for me it does. In tight spaces, it's a real PITA, but it sure holds the cable form so much tighter, and looks more professional if you take the time to comb out the criss-crossing tendencies of the wires being bundled. On long harnesses, I'll always have an un-tightened spot tie that I continually move down the bundle, while applying the permanent spot tie in the spaced intervals.
                        In re-packaging jobs, such as rack-mounting a pair of Yamaha PM1000 console modules, I found it much nicer using lacing cord than cable ties.
Name:	Module Harness Wiring-1.jpg
ID:	851855 Click image for larger version
Name:	Module Harness Wiring-4.jpg
ID:	851856 Click image for larger version
Name:	Module Harness Wiring-5.jpg
ID:	851857 Click image for larger version
Name:	Chassis Harness Wiring-6.jpg
ID:	851858 Click image for larger version
Name:	Chassis Harness Wiring-7.jpg
ID:	851859 Click image for larger version
Name:	Chassis Harness Wiring-8.jpg
ID:	851860 Click image for larger version
Name:	Testing Modules-1.jpg
ID:	851861 Click image for larger version
Name:	PM1000R 2 CH Mic Preamp-6.jpg
                          I had to look that up. Glad I did.
                          I've been trying to wrap long extension cords in an over-and-under coil, like mic cables. PITA, and doesn't work so great if the cord has "memory" of previously being coiled in a continuous spiral.
                          This method might work for short cords, but sure takes up a whole lot of space:
                          https://www.youtube.com/watch?v=TkYQWJl3Zv8
                          This "folding" method looks like the way to go. I just wish the camera frame didn't crop off the bottom of the loops.
                          https://www.youtube.com/watch?v=HRDkYSSCF1A
                          -rb
