Cooling fan and tube life
  • #46
    Yes, exactly. Better still, drill a hole in the tube and fill the insides with automotive coolant.
    • #47
      Thanks Enzo. After some additional reading, I found that high speed steel drill bits work on glass.
      And I happen to have an extra water pump left over from my dad's '65 Ford Fairlane 500.
      This is going to be the coolest amp in world history.
      • #48
        Ever wondered why there needs to be vacuum (= nothing) between the electrodes?
        • #49
          Nothing except for a gazillion electrons but they are just passing through.
          • #50
            Sure, but anything else would cause collisions.
            Also cooling the cathode wouldn't be a good idea.
