5F6A build: first time using 220V tap
  • 5F6A build: first time using 220V tap
    Hi guys,
    I've built over 10 5F6A's over the years and have to build one for 220V mains.
    I'm going to be using the Classictone 40-18029 PT and was wondering, besides putting in a fuse with half rating of 110, are there any other things I need to be aware of?
    Do you have 220v to test it?
      Out of curiosity: Where is the amp going to be used? (Europe has 230V mains.)
        I will be buying a step up transformer.
          UK.
            Apparently the transformer has primary taps for 100V, 120V, 220V and 240V.
              Whilst the eu harmonised official uk nominal mains is 230V, in reality it’s still maintained at the pre harmonised 240V.
              Dunno how much difference the 50Hz would make.
                Definitely use the 240V tap for the UK.
                I often measure over 250V here (mid Cheshire)
                  Thanks Dave....i was going on what my buddy told me but 240V is right.
                    So other than using the 240 tap, the rest stays the same?
                    Someone told me to use a lower rated fuse.
                      That "Thumbs Up" wasn't to say "use a smaller fuse." It was meant as "I have seen the same proposition & have the same question."
                      Justin
                        The mains/primary fuse for 240V should have half the current rating of the 120V version as primary current is reduced by around 50% for the same power.
                          Can you find the correct Mains plug to ship with the amp ? Will the amp have an IEC inlet and the customer will supply a Mains cord set ?
