Hi all! First time posting here after years of browsing and taking notes. Thanks for all the help so far
I'm wrapping up a custom build and trying to iron out an issue with my filament supply. The heaters for the first three preamp tubes will occasionally go out - not intermittently but just be completely off when I power on the amp.
I first ran into the issue when I wasn't getting any sound through the amp and noticed that the first three 12AX7 tubes weren't glowing at all. Oddly enough, the fourth preamp tube(12AT7 LPT phase inverter) and the power amp tubes(4X 6L6GC) do glow. Then I go pop open the amp to measure the AC voltage on the heaters, and sometime thereafter the heaters for the trouble preamp tubes eventually come back. This has happened on a couple separate occasions. I've double and triple-checked my wiring but am totally stumped at this point! Also worth noting that I have an artificial center tap on my filament supply, 100ohm 1/2W resistors to ground.
Anyone have ideas on what might be the issue here? I thought maybe it's a short in the filament supply, but I imagine this would affect all the tubes+lamp rather than just the three.
