Hello,
I trying to implement some (6db arround) nfb into my project. For some reason testing at 1 kcps with square wave is ringing a little bit too much. I tried to compensate with a capacitor over 1.5k series resistor , I usually did, but seems nothing work. Started with 500p then 1n then 2.2nf then 4,7n with no results. At 10nf it already get severe oscillations. Any thoughts how can I make it little stable,please ? Thanks
Late edit: I tried cut the high freq bypassing plate resistor into first stage with no results. The fault is from closed loop and didn't know how to compensate. The classical method bypassing series resistor didn't work for this circuit
Can be a issue of the 100uf elco and its incapacity to decouple effective in high freq, pls ?
