I am trying to track down an annoying reverb hum in a Princeton Reverb kit build. The amp was built from a Weber 6a14 kit using the schematic and layout provided by Weber (which I have attached for reference). I used the brass grounding plate and the non-isolated RCA jacks included with the kit. The hum is not present with the reverb turned to zero or switched off with the footswitch. it is progressively louder as the reverb knob is turned up. It is present and behaves this way with the volume at zero and nothing plugged in. Here's what I've tried so far to fix it:
1. I wrapped the two wires from the reverb pot with a wire and grounded it at the pot as an attempt at shielding. (The wires were already twisted together from the original build).
2. I replaced the RCA jacks with jacks that are isolated from the chassis and ran a grounding wire to a spot near the input.
3. I replaced the wire from pin 2 of V3 to the reverb pedal jack with a shielded wire grounded at the jack end.
4. I replaced the wire from the reverb pedal jack to the reverb output jack with a shielded wire grounded at the reverb pedal jack ground.
These changes made no difference in the hum.
I used a signal tracer to try to figure out where the hum is being introduced into the signal and determined that it first shows up on pin 6 of V3. From there it carries through the circuit to the speaker. I tried several different 12ax7 tubes in the V3 position with no change.
I would appreciate any ideas as to where to go next with my troubleshooting.
Thanks
(I've cross posted this in the Weber amp building forums as well)
Thanks
