Hi all, my name is Horacio and I'm from Brazil, my first post here!
I would like to build a system that consists of a power amp and a 2x12 cabinet. No pre-amp will be used, this will be combined with a POD effects processor. There is no need for extreme power, it will be used at home and for small presentations. I was going for something around 50-100W to keep a safe margin.
I was recommended this Guitargadgets' project for the power amp part: Power Amp. What do you think of the schematics? Do you know a better one based on the LM3886? It still needs a power supply, though. There's a schematic for that at GGG too (Here).
As for the speakers, which do you recommend? I play all kinds of music, from jazz to rock, an all-round speaker would be ideal. As I said earlier, I don't need much power. Instead, I go for quality, since this amp will be with me for a long time
I've heard that the LM3886 heats up quite badly and that it is a concern. Is that true? (By how far, if so?) Will it need any special cooling?
Thanks in advance for the help, guys!!
