First, here's my (limited!) experience building tube amps:
My first amp was a Valve Junior copy with switches to change component values. The switches change cathode bias resistors and bypass capacitors, the first stage coupling capacitor, and a treble bleed cap on the voltage divider before the volume control. This worked fairly well, but the effect on the tone was more subtle than I expected. (The component values were chosen based on the "Voxy", "Fenderish", and "Marshallized" mods listed on the turretboards.com Valve Junior page.) This is still one of my favorite amps.
My second and most recent amp (told you my experience was limited!) has two(!) additional gain stages, a TMB, and a master volume, using the 2.2uF 93Hz shelving cathode bypass caps suggested in the Marshallized mod on the aforementioned page. I quickly learned that four gain stages is *way* too much, so I removed the last gain stage from the circuit. This is my current practice amp (when I practice with an amp).
Then I perused some of the schematics at schematicheaven.com, and was duly humbled. Hence, my current project, which is still on paper:
I'm currently in the process of laying out an amp which, by way of relays on the circuit board controlled by a fairly complex footswitch system, will hopefully be able to bypass gain stages and voltage dividers, switch bright caps in/out, and yes, change cathode bias resistors, cathode bypass capacitors, and coupling capacitors, turning the preamp into a copy of a JCM 1959, a slightly modified JCM 2204, a Vox TB, a Fender Princeton, or any of literally thousands of (hopefully) usable amp sounds that incorporate elements of each of these four well-known amps.
My question is: Has anything like this been done before? Does it even sound feasible?
I'm posting a copy of the schematic, which will hopefully clarify what I'm trying to do on the amp side of things - the "one-of-N" latching circuit for the pedal board still needs some kinks ironed out. The relays are drawn as simple switches; three of them are DPDT bypasses, but that should be fairly obvious from the wiring.
