2X12 Cab, need help
  • 2X12 Cab, need help
    I am planning on building a 2X12 cab, and am basing my design on the dimensions of the VOX AC30. I have never built an amp before, and am looking for some suggestions. I play classic rock and blues, and like the "open back" sound of fender and VOX amps. I was planning on using maple for the body of the amp, and relatively thin plywood for the baffle (floating baffle).
    I was inspired by this particular project: http://www.vintone.com/rc_ac30_o
    and was wondering about the sonic properties of mahogany, or any wood for that matter.
    I will use a pre-built head (any suggestions?), as I have no experience with electronics. For speakers I think either celestion blues, or tone tubby hempcones.
    tell me what you think
    Edit:
    Also, I need help getting the right head for the right speakers, with the right wiring. I have no idea how to get the impedance correct
    sounds like you are on the right track, but i'll give you a few comments.
    maple (or mahogany to a lesser extent) for a cab is going to be quite heavy. it will be stiff, but not nessesarily better tone wise for a classic rock/bluesy sound. older fender amps were made with pine, which actually resonated and effected the way the amp sounded (most people liked the resonance it provided, and seems to be a sound you may like). otherwise plywood should be fine for the cab assuming the design is plenty strong. plywood may be a bit more durable than pine in terms of resisting dings.
    for wiring up the speakers, you want 2 speakers of the same impedance. wire them in series and you add the impedance, wire them in paralell and you divide them by 2 (for 2 speakers). so if you need 8 ohms, you would either put 2 4's in series, or 2 16's i paralell
