5F1 Questions
  • 5F1 Questions
    Looking at a 5F1 layout, where are the following located:
    Cathode circuit of the output tubes?
    Main filter cap ground?
    The screen supply filter cap ground?
    Preamp cathode circuit grounds?
    Preamp grid return circuit grounds?
    Preamp filter caps?
    I am just starting a build and need confirmation. I trying to determine my ground scheme. I think I will run my preamp grounds to the brass grounding plate and my power section grounds to a star ground at a PT bolt. Doing it this way what would be the best way to ground both the input and speaker jacks?
    Does anyone have experiance using a ground bus on a 5F1? Run through the input grounds, soldered to the bake of the volume pot and then to a PT bolt?
    Thank You
    Take a look at Angela amps project on single ended 6V6.
