Im trying to identify all ceramic disc caps in the Deluxe REvereb AB763 circuit. I think one is on the back of a pot, maybe? I found a bunch of photos, but it looks like one with 'brown turd' caps must be later, maybe 70's, has one brown cap instead of a ceramic?
identifying all ceramic disc caps
Sorry, I thought I’d already replied - the caps marked 4 and 3 would typically be film types, rather than ceramic.
Regarding your second query, a flaw in trying to lump all ceramic caps together as one thing is that they aren’t. Class 1 types are very linear and temperature stable (eg NP0 dielectric), whereas other classes can be the polar opposite.
See https://en.m.wikipedia.org/wiki/Ceramic_capacitor
Typical tube guitar amp suppliers don’t tend to note the spec of the ceramic caps they’re selling, thus compounding confusion and misunderstanding when the topic is discussed on tube guitar amp build/repair/modify forums.My band:- http://www.youtube.com/user/RedwingBand
- 2 likes
And I say again, it is just a guitar amp, not precision lab gear. You might find film caps in one amp and ceramics in another in certain spots. The 63 in AB763 means 1963, if you amp is from 1970, chances are it is not identical. So don't assume there is some cosmic "correct" cap for each component. Old Fender amps were built with 20% tolerance resistors, and the tolerance on caps back in that era was all over the map. And pots? A 250k pot might measure at 400k. Ballpark is as close as it gets there.Education is what you're left with after you have forgotten what you have learned.
- 1 like
Originally posted by pdf64 View PostSorry, I thought I’d already replied - the caps marked 4 and 3 would typically be film types, rather than ceramic.
And thanks Dude, looked as hard as I could, could not find two 1uf Are those the caps that sometimes appear on output tubes?The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Haha, I think The Dude just meant that electrons behave the same, whatever the cap dielectric.My band:- http://www.youtube.com/user/RedwingBand
- 2 likes
Fender Capacitor Codes
CAP AE = Aluminum Electrolytic
CAP CA = Ceramic Axial
CAP CD = Ceramic Disk
CAP MPF = Metalized Polyester
CAP MY = Mylar
CAP PFF = Polyester Film/Foil
http://www.thevintagesound.com/ffg/deluxe_reverb_bf.html
https://images.reverb.com/image/upload/s--Ot5_DUXJ--/f_auto,t_supersize/v1598934362/efto7rcc2lbnq8xma58n.jpg
Who does not know and knows that he does not know - teach him Confucius)
Who knows and does not know that he knows - wake him Confucius)
- 3 likes
And the class types of those ceramic disc / axial caps are???
Without that detail, it’s pretty much pointless, non-info.My band:- http://www.youtube.com/user/RedwingBand
- 1 like
Originally posted by pdf64 View PostAnd the class types of those ceramic disc / axial caps are???
Measuring the capactive Q-factor with an LCR meter might give some info.
I also use the Q to tell between polyester/mylar, polypropylene and PIO caps.Last edited by Helmholtz; 09-17-2020, 03:31 PM.- Own Opinions Only -
- 1 like
http://ampwares.com/schematics/65_Deluxe_Reverb_RI.pdf
1)
Fender uses coded naming convention in the description of certain parts.
The codes and what they mean are described on page 2 SM.Who does not know and knows that he does not know - teach him Confucius)
- 1 like
That seems to provide the voltage rating, cap nominal value and tolerance, but not the class type / acceptable limits for parasitics, eg temperature coefficient?My band:- http://www.youtube.com/user/RedwingBand
- 1 like
Guitar amplifiers koriste consumer electronics parts.
Most likely something like
https://portal.edge-group.com/~edgegro1/members/marketing/datasheets/nte/90000.pdf
- 2 likes
Every serious manufacturer (amplifier) in the process of development connect for some supplier of parts, and according to chosen parts makes its own coded naming their own built-in (spare) parts.
The parts to be installed supports the minimum design and technical requirements, both in voltage (capacitors) and in power (resistors).
Transformers generally follow technical datasheets recommendations from good old handbooks (vademecums) for projected tube (s).
Everything else is technology and modern design.
About spare parts ... ...
https://portal.edge-group.com/~edgegro1/members/marketing/datasheets/nte/89000.pdf
https://portal.edge-group.com/~edgegro1/members/marketing/datasheets/Who does not know and knows that he does not know - teach him Confucius)
- 1 like
