Just in case it's an issue, are you using an old version or new version of the OT wiring? The secondary of the older ones is not quite simple.
Negative feedback problem Help
That doesn't make sense. Output phase should invert.
Please see post #27."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by g1 View PostJust in case it's an issue, are you using an old version or new version of the OT wiring? The secondary of the older ones is not quite simple."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
- Likes 1
Originally posted by catalin gramada View PostStill don't get it. What ot tap for this OT should be grounded please ?- Own Opinions Only -
- Likes 1
You should ground the 0 Ohm secondary wire as shown in the OT specs and repeat the scope measurements and tests. If output and input are out-of-phase, reverse the OT primary wiring.Last edited by catalin gramada; 12-29-2020, 09:57 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
This is something already did: with black common wire at ground and reversing PI phase did not do any difference: The signals are out of phase. The only thing I tried and put the output signal with input signal in phase was to reverse the common and 8 ohm output taps.
Of course you can't reverse the grid signals at the same time as this would turn the phase back again.- Own Opinions Only -
- Likes 1
