Hi MEF'rs.
I have an old Lanely LA60BL, from the late 60's. In most ways it is very similar to a late 60's Superbass circuit except perhaps v1 Rk components. I also already have several Marshall type builds... a JTM45, a 1987, a 1959, and 2203 circuits. What I love about the Lanely is that the sound is generally fatter and more clear - especially in the bass and low mid frequencies. Highs seems to be a bit more mellow as well, but it could be the circuit doing that. I can only assume that a big part of the reason would be the Partridge output tranny (TG9686) and a much higher B+ (hovering 570-600VDC from memory).
Would this be a proper assessment? Is this output transformer considered to be more "hifi" than the standard Drake/Dagnalls of the late 60's/70's?
I am trying to understand output trannys better... winding styles etc and their resulting characteristics. But it is a lot to take in.
Anyway, I am thinking of putting in as similar a set of transformers that I can find to these partridge trannies into a new 1987'ish build I am starting to collect components for. What I have found is that the transformers that usually come recommended (new production, probably Inmadout) for a Hiwatt DR504 may do the job as they seem to have similar characteristics (on paper)...
As seen here: https://www.tube-town.net/info/daten...4-pw-v2020.pdf
Power Tranny for HiWatt DR504
Secondary: 350 - 0 - 350
Filaments: 3.15 - 0 - 3.15
Bias: 50V
The dedicated bias tap is a nice feature.... but if I am correct, rectified power should come to just under 500VDC. Correct? (700 x .71 roughly)
Output tranny for Hiwatt DR504 - https://www.tube-town.net/info/daten...t-dr504-ot.pdf
Primary: 3k8Ω
Secondary: 4, 8, 16 ohm
Max: 75 watt
I hope that a standard 3H, 100mA choke would work in this scenario? Or would I require something... beefier?
To be used with a set of EL34, new production. I typically use TAD or Harma since I have had much less failure rates than factory branded, off the shelf stuff. Actually as far as TAD and Harma both go, I have yet to have a failure after a few years.
So, am I barking up the right tree here? Thanks for your input... I would feel better to know I am making an okay move here. I am not afraid to face replacing them if it doesn't work out sonically... but I never like to just jump in the deep end on my own limited knowledge and experience.
Bias: 50V
Primary: 3k8Ω
Max: 75 watt
