Hello. Built the exact replica of stacked power supply as Hiwatt did (less stb indicator). The standby switch makes the amp thud as hell quake when switch on. The switch supply directly voltages to the plates and grids. Any ideea to suppress the thud with the stb switch in those position please ? Thanks.
Standby switch question
Last edited by catalin gramada; 06-06-2021, 12:43 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
I tied the OT in UL configuration for a test. Same standby switch configuration after the bank caps linked directly to OT. The only noise I heard is mechanical click of the switch. No pops or thud at all. Think the thud is a function of how the pentode is supplied. If cannot be suppressed maybe the first power on transient can be canceled by a perfect balanced stage ....?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by Leo_Gnardo View PostYou might try having your standby switch work only on the screen grids. Some high power amps do this, Ampeg SVT Classic is one IIRC. Worth a try, it will be a fast & easy experiment."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
- Likes 1
Originally posted by catalin gramada View PostI tied the OT in UL configuration for a test. Same standby switch configuration after the bank caps linked directly to OT. The only noise I heard is mechanical click of the switch. No pops or thud at all. Think the thud is a function of how the pentode is supplied. If cannot be suppressed maybe the first power on transient can be canceled by a perfect balanced stage ....?
Maybe the screen section of the switch tends to chatter?
Or the screen voltage switching produces an oscillation burst?
Do you know if the Hiwatt 200 also suffers from this problem?- Own Opinions Only -
- Likes 2
